#82556 - 20/03/2002 09:44 Fast connection questions for Empeg guys
mschrag
Loc: Richmond, VA
1) It appears that sometimes trying to open a fast connection doesn't work (the connection to 8301 is denied). Are there scenarios where you can't obtain a fast connection?
2) Is the emptool fast connection implementation reliable? (i.e. if I did a straight port of that, should it work) I notice that the fast connection is only closed when the Connection is _paused_. (not when it's closed). In fact, it looks like if I close a fast connection, I can't seem to open it back up again reliably -- is this crazy talk?
3) Does Jupiter support fast connections?
4) If an upload stops in the middle, do I need to somehow reinitialize the fast connection, or by just sending a new TcpFastHeader, will it reinitialize automagically? (coincidentally, or perhaps not, pause is called when the database is reloaded, so the connection would probably be restarted then)
Mike
#82557 - 25/03/2002 15:46 Re: Fast connection questions for Empeg guys [Re: mschrag]
mschrag
Loc: Richmond, VA
No comments? Anyone?
#82558 - 25/03/2002 15:52 Re: Fast connection questions for Empeg guys [Re: mschrag]
I think the empeg guys probably just didn't see this post. Either that or they're busy with something else.
#82559 - 25/03/2002 19:47 Re: Fast connection questions for Empeg guys [Re: mschrag]
There are two ways (at least) for a TCP connection to be rejected:
(1) low memory: a temporary condition, seems unlikely, but the solution is to wait a small amount, and then try again.
(2) Player software not currently listen()ing on that port.. maybe it is slow to return to listen() state after a previous connection is closed.. ? Same solution, though..
#82560 - 26/03/2002 10:59 Re: Fast connection questions for Empeg guys [Re: mschrag]
Yeah, that doesn't look right. It certainly looks like the fast connection wants closing in Close(). Maybe your connect failures are where a previous session has left the socket open. Although in theory you shouldn't be writing FIDs to the player without rebuilding the database (which includes pausing the connection).
Yes.
If a fast-channel operation stalls for 10s or more, the player will close the socket. Subsequently you should be able to establish a new connection.
#82561 - 26/03/2002 11:11 Re: Fast connection questions for Empeg guys [Re: mschrag]
Mike, many developers here don't have time to read the BBS any more, or just skim read. If you want to be sure of getting seen, use the alpha list.
#82562 - 26/03/2002 11:48 Re: Fast connection questions for Empeg guys [Re: rob]
I think he was trying not to use the alpha list for a developer question. There was a complaint on the alpha list recently that they did not want it to turn into a developer's list.
#82563 - 26/03/2002 13:02 Re: Fast connection questions for Empeg guys [Re: tfabris]
There's already a developers' list. It's just that nobody seems to use it:
http://www.empeg.mars.org/devel/mailinglist.php3
#82564 - 26/03/2002 19:58 Re: Fast connection questions for Empeg guys [Re: peter]
mschrag
Loc: Richmond, VA
Have you ever seen an attempt to connect to 8301 fail?
Mike
#82565 - 27/03/2002 04:51 Re: Fast connection questions for Empeg guys [Re: mschrag]
Not in released software, no.
(And I'm sorry I didn't see this thread earlier; I don't know how I managed that as this is one of the forums I try to at least scan.)
#82566 - 27/03/2002 06:16 Re: Fast connection questions for Empeg guys [Re: peter]
mschrag
Loc: Richmond, VA
I'll just check my code my thoroughly -- I must be doing something weird.
No problem about missing the thread -- I mean, most other companies would just leave developers to fend for themselves -- I have a 100% success rate at getting my questions answered (no matter how esoteric). So thanks for taking the time at all.
Mike
