#87002 - 12/04/2002 02:49 empeg web interface
mpelaz
Hi everybody
I'm trying to upload the 'empeg web interface' archives i just downloaded as a zip (cgxslv1.2.zip). It's supposed to run when copied to " / " directory, but it doesn't let me copy anything...
Riocar is running both last releases of Hijack and kernel. I'm using M$ IExplorer 6.0 as ftp terminal.
How can i open the write attribute ?
Note - Here in the office i only have a Ethernet connection...
Miguel
Madrid
60Gb blue MKIIa +PCATS tuner on a Seat León 20vt FR
#87003 - 12/04/2002 03:45 Re: empeg web interface [Re: mpelaz]
Greetings!
You probably have not set the disks to read/write. The command is "rw" to remount the root filesystem as read/write, and ""rwm" to do the same to the music partition. NOTE: you MUST use "ro" and "rom" to set them back to read only before exiting the shell, or you may cause damage to your filesystems and it will force a disk check on your next sync.
#87004 - 12/04/2002 12:45 Re: empeg web interface [Re: pgrzelak]
justinlarsen
Loc: Petaluma, CA
whoa paul am i reading right in your signature you have 2 120gb empegs? thats boggles my mind.. one woudl be cool but 2! how full are they?
---- Justin Larsen
