I'm getting the same problem of slow resumes and battery icon when in the car.
Tony, weren't you gettting a similar problem? Did it just go away?
I don't have a problem of slow resumes. I also don't activate the screen blanker, and my player doesn't mysteriously drop in and out of standby.
I do have the following charging system problems, though:
- When I start the engine with the player playing, the player either blanks and battery-icons, or it fully reboots. I figure this is normal.
- If I am running the player purely on battery power (engine is off), and a particularly bass-heavy song comes on with my volume loud, the increased drain the subwoofer puts on my poor little Honda battery will make the player blank and battery-icon. I could theoretically solve this problem by installing a big capacitor. Haven't done that yet, NWMT.
- If I run the player with my engine off, there is noticeable ground-loop noise in the system. I think this is due to the low voltage. As soon as I start the engine, all ground-loop noise disappears. Again, NWMT to fix since I rarely want to listen with the engine off.
