Could it be something with Patrick's Tuner kit? And when i say that, i mean something I did to screw up Patricks Tuner kit?
Hm. Did you say that you had a steering wheel remote? Is it one of the wired remotes, sony-style, plugged into the tuner module? If so, those things work on resistance. And random resistance values might do exactly what you're describing.
Question... Were you one of the folks who'd accidentally installed one of the tuner kit's components upside-down at first? If so, which component? Perhaps that did something to make the tuner kit get random fluctuations from the steering-wheel-remote electronics and is causing the behavior you're seeing.
For what it's worth, my player with the tuner kit exhibits none of the symptoms you're describing. But then again, my kit worked the first time.
