The nice thing about STP is, you can initially just ignore the fact that it is shielded, and use regular connectors and stuff.
The important future-proofing part is just ensuring that you have it inside the walls. If you ever need to use it's full bandwidth capabilities, then at that point you can upgrade the connectors and stuff.
Just be sure and leave a slack loop behind every wall box -- a good idea regardless.
