I also can't seen to be able to find Cat6A RJ-45 jacks for use with STP cable. It's like they don't exist!
That's because Cat6a doesn't specify STP.
It doesn't? That would be a good reason, of course. I guess regular Cat6 RJ45's can be used then. What else would be there to use?
All the RJ45 connectors I've used in the last five to ten years have been able to deal with both stranded and solid. Regardless, go with solid cable.(...)
Yes, my reading up on this has taught me that solid cable is always used for cables that are put inside walls. But as you say, I'd probably use solid cables regardless. If I ever needed a real flexible cable, I'd buy a pre-made one.
