The LED strip's black wire is actually marked +12v, so it might be one of the strips you would think are wired for that controller. But it most definitely does not work if you apply +12v to that wire and then ground any of the color wires.
Sounds like the factory messed up and accidentally printed up a common-cathode strip as though it was common-anode (which presumably they also make), then supplied it to your supplier as common-anode. You should take it up with your strip supplier, maybe they got a whole batch which were mislabelled...
