OK, here are the last dozen or so lines on the serial line that are the problem. The player pauses at probing primary interface for about 10-15 Seconds.
empeg single channel IDE
Probing primary interface...
smc chip id/revision 0x3349
smc9194.c:v0.12 03/06/96 by Erik Stahlman (
[email protected])
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:10:00:8
3
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...VFS: Cannot open root device 03:05
Kernel panic: VFS: Unable to mount root fs on 03:05
There you go, what do you think?
Alex Lear
