The pressure assist ones have a poly tank inside the actual tank. It doesn't run off of electricity so no need to plug it in.
It holds air and as it fills up with water, the air compresses and then when you flush this compressed air helps push the water out quicker.
Another positive to this is that these don't "sweat" like a standard porcelain tub because the water is actually held inside the poly tank.
