Just to make things easier...
You can modify a us toilet to higher flow. Many are built with oversize tanks (you can identidy these by the water level mark inside, if it's only half way up, it'll hold more water) and you can install a float valve meant for an older tank in it. I've done this and it works as well as the old ones did.
