But the problem with those and with the mounting holes in general is that they're in a rectangular pattern, not square. The switches were in a square, so rotating the mounting brackets was possible, even though the switches weren't intended for wall mounting either. It doesn't look like I'd be able to rotate the mounting brackets even if they were included...
I was thinking of putting L brackets on the wall and then hanging the router off those by the rackmount ears which you attach normally. That way it doesn't matter what arrangement the actual attachment holes are on the router because you only care that the rackmount ears will fit which they should do as its a Cisco part.
