#7687 - 01/03/2000 02:42
Re: Sync failure, stage 5, 0x800703e4
Hi,
From the other thread running on this subject, mac put out a emplode update to fix the 0x800703e4 error:
The sync error being discussed in this thread has nothing much to do with what you do, whether you modify playlists or upload tunes or whatever. As far as I can tell it is only to do with:
1. Running Windows 98SE. 2. Doing a reasonably long synchronise (at least once in a Windows session).
I believe the problem is due to power management changes in 98SE. I've got a version of emplode that reduces the number of times the error happens but doesn't actually completely eliminate it. If you want to try it it's available at http://www2.empeg.com/upgrades/test/interim/private/emplode-0.84.2.zip.
If this doesn't help then try turning off every single power management feature you can find.
I've been investigating the USB driver to find out exactly what needs to be changed but I haven't found anything conclusive yet.
And a new version of the empeg software to combat an out of memory error 0xffffff...
It means that the player has run out of memory (RAM, not disk) which is odd. Try this update and see if it helps: http://www2.empeg.com/upgrades/test/interim/private/developer-beta9c+.upgrade
Even mac agrees that the new emplode version doesn't solve the problem, just makes it less likely.
I'm going to try the new emplode tonight, but I've no need (I think) to try the 9c+ release for the empeg, right mac?
Paul
Paul Haigh, 6GB, Blue Reg: 4120 - Serial 00254
Paul Haigh, Reg. 4120
(mk1) 6GB, Blue, 00254
(mk2) 12GB, Red, 00357
pgillingwater
21/02/2000 04:40
phaigh
29/02/2000 14:50
Clarke
29/02/2000 19:49
phaigh
01/03/2000 02:42
Beta 9c+ seems better
pgillingwater
01/03/2000 05:46
Re: Beta 9c+ seems better
pgillingwater
01/03/2000 08:05
Big John
02/03/2000 05:17
Clarke
01/03/2000 19:43
ARGH!
Clarke
02/03/2000 20:14
Hmm..
Clarke
02/03/2000 20:15
Re: Hmm..
Lord Bleys
02/03/2000 21:17
Big John
01/03/2000 04:04
Henno
03/03/2000 04:45
Lord Bleys
03/03/2000 20:52
schofiel
05/03/2000 08:32
Henno
05/03/2000 10:43
schofiel
05/03/2000 08:28
Re: Not just a USB error (was sync failure 0x800703e4)
Henno
05/03/2000 10:29
Henno
05/03/2000 11:11
rob
06/03/2000 07:45
Henno
06/03/2000 08:15
mac
06/03/2000 10:54
Henno
06/03/2000 12:00
mac
07/03/2000 03:29
mac
09/03/2000 07:44
rob
13/03/2000 08:36
phaigh
13/03/2000 11:23
Henno
13/03/2000 12:07
mac
14/03/2000 03:19
Henno
14/03/2000 13:46
mac
15/03/2000 03:58
Henno
15/03/2000 16:53
mac
16/03/2000 04:09
mac
13/03/2000 09:32
mac
14/03/2000 03:11
Henno
13/03/2000 17:01
