FWIW, other than creating a boot CD, the SP3 executable provides slipstream support itself.
Just copy the original CD to a hard drive, then run "SP3.EXE /integrate:C:\path_to_cd_copy"
I kinda distrust nLite after that weird slipstream experience I had.
At one point there used to be an issue if you used Vista to slipstream an XP CD because the installer would pick up something from Vista instead of the XP media. nLite and the others worked around it or you could try getting the SP3 executable to run in XP compatibility mode.
