Yes.
eg, if you are in tuner mode and do something that causes the display to go off (eg, start the engine) when the display comes back on you won't get the antenna line powered - hence you'll get worse reception. You need (on 2.0b3) to switch to mp3 mode and back in order to force the line on again.
This is FITNR.
Hugo
