Well, no, but if you're seriously going to rename a file using only your left hand, then you're probably not in much of a rush to begin with.
That is true. I can see some reasoning for it, although I would still say that with how Windows operates, it would still be an unintiutive action for the enter key, which is generally used to perform actions, usually the same actions as the left mouse button. switching up the use of the key would be confusing. F2, on the other hand, is used in many applications as a rename key (I use it in Excel all the time).
Personally, I find that all GUI-based systems are easy to use for beginners but difficult to use for experts.
That sounds like a good assessment.
